hi i downloaded some games in zip format when i opend it i can't find any .jar or .sis file.
one answer i got is go to
startmenu -> settings -> folderoptions -> view tab, check display file in full path
but this is using windows 98, m now using windows me.
any idea how i can rename the zip file to jar?
tnx
Just rename using Windows Explorer like you would rename any other file.
i tried that already but when i sent the file the file name was mypet.jar.zip
hehehehe....
This is because you have windows set to hide extensions of known file types. Just set windows (extra-folderoptions or something) to show all extensions. Then rename in explorer.
use the pc suite to rename the file
You dont have to rename it to anything, as it is already a .jar file. Just send it to phone.
