If you goto
Control Panel
Sounds and alerts
Other
There is an option for voice messages.
What is this for?
Searched though the manual but can not find anything for this?
Any1 know?
If you goto
Control Panel
Sounds and alerts
Other
What is this for?
Any1 know?
could it be when your networks voicemail sends you a message saying you have a new voicemail message that it'd make that sound?
Thought it could be that.
Set the sound but it still only makes a normal sms sound.
Checked to make sure the right number was in the voice mail settings as well.
And that i got the message from that number. I do.
So dont think its that.
Unless i missed something in the settings somewhere!
their are two types of voicemail notification, their's the message one but also where they ring you up and tell you you have a nu voicemail, if you then stay on the line long enough, it will connect to your voicemail inbox automatically. wheeeeeeeeee
