Themes on the 6600 (again!)
15 replies · 6,335 views · Started 30 November 2003
Sorry to sound a bit dense, but when how do you install a downloaded theme on the 6600?? I send it to my phone by-way of bluetooth, get the message saying that I have a new message, but when I try to save it it will just save an image and not give me the option to save it as a theme!! Please help!
yes, the file is automatically saved in gallery.
then you would have to use the fexplorer to find the file and cut and paste it to where the climber.mbm is located and rename the originial climber.mbm.
the new downloaded theme should be renamed to climber.mbm so when u choose the climber.mbm theme it would recognize the new one.
the climber.mbm is in drive E:\system\skin
So where is this fexplorer? I have only had the phone a few days and am still getting used to it. How do you cut and copy the file from the gallery to the skin folder. Could you post some step by step guides to do this?
Sorry again, it's embarrasing to be this thick!
its ok, i myself was kinda confuse with this .mbm thingie.
just post ur email add or better yet send me an email
[email][email protected][/email] then i'll send u the fexplorer file. it's a better file manager than the one installed by nokia.
u can browse all ur folders/files there using the explorer.
just be sure u downloaded the original climber theme using wap. just search the topics about themes regarding the climber.mbm site.
Originally posted by 6600_Rich
Done, Thanks Sheri!
Hi I'm Laszlo from Hungary, can you sent me too how can I use any mbm.file on my 6600
sherry
when i click 2 download ne theme from nokia syt its start downloading up to 99% then automatically msg prompt on screen that service unable 2 perform opration
help me
hem
Hi sheri
i had install theme renaming. Bt how cn i installed more dan 1 theme bcoz only 1(new) theme located ere
The climber.mbm shoul be in the e:\system\skin........but on my 6600 it's not in that directory :S There even isn't a E:\system\skin...... i only got e:\system\apps and E:\system\install
How is this possible? Where can i fnid my climber.mbm?
I hope someone can help!
Hi i had suksesfly rename theme bt whem i had open theme the screen bcm white .
hi,
did u rename the right theme? u have to rename the them u want to climber.mbm and be sure to choose the them with the .mbm extension coz the cyrstallize theme has lots of bmp files and 1 mbm.
Hi sheri
did u tel me ful procedure? I had already dwn load crystlzed theme 2 e:/othor n climber installed n e:/system/skin
hi,
T-BOR >
I'm using the Crystalized theme on the 6600.
My Climber mbm is found in :
C: System : SKINS
In the SKINS folder there are 4 or 5 different folders with some names/numbers,..go into one of them,..there you should find Climber.MBM.
Rename it in there 😊
And yes,..I use EPOCWARE's Handyfile,..works great 😊
BR
Jan
What are you all on about???????????
If you download the sis file to your pc then transfer via Pc Suite into install files there is no problem whatsoever**************all this talk about mbn,explorer,triple A over head manifold sprockets etc...MMMmm
ELTON >
I suggest you READ THE DATES of the replies !!!
When themes came along there was NOT any SIS files,...
only MBM....
So TRY reading the posts before saying something stupid like "WHAT ARE YOU ON"
Jan
