I need a backup for 6600
7 replies · 2,496 views · Started 01 December 2003
please can one send me a backup data of original 6600
because my phone is going crazy. I erased some data by mistake
Reformat: #*7370# (default lock code is 12345, if you haven't changed it). Make sure your battery is charged fully or the phone is on AC when you do this. All data, settings, user installed apps, contacts, messages, etc., will be gone after this.
what about buy&try Kodak, pictures,Opea and print
what is going to happen to them
Nothing will happen to the MMC. If it is the MMC contents that you've lost, then there's nothing I can do to help (I don't have a 6600 or the MMC it comes with).
I found the applications there but they are not free. I have to buy them ( the Application KEY )and there are no trail versions .
can some one tell me how to get these applications back, because I've deleted them
wayfinder
worldmate
solved
quickbook
pictuers
zipmate
okay friends I really need I backup of a brand new nokia 6600
because I did ruin my mobile.
It is going crazy .
please help me ,
Help me
