I have the last version of TDK Bluetooth adaptor (1.3.2.7) but I can't connect the Nokia 6600 with this adaptor....
And you, do you succed ?
ONLT download http://www.mavintec.com/download/usb.zip this driver 1.4.2.10 and change this form crack www.gsmhelp.org/newdownload/1.4.2.10crack.rar
When the installation asks BT-dongle drivers click next and then copy these files to the right places:
wbtapi.dll
-> C:\windows\system32
BTStackServer.exe
BTTray.exe
-> C:\Program Files\WIDCOMM\Bluetooth-software
(Folder where you installed the soft)
If the copying progress says that "Could not overwrite because the file was in use etc...",Task manager and proccess
The gsmhelp.org/newdownload link doesn't see anything (page not found). has it moved, can I get it somewhere else?
Jeff
Originally posted by inox
ONLT download http://www.mavintec.com/download/usb.zip this driver 1.4.2.10 and change this form crack www.gsmhelp.org/newdownload/1.4.2.10crack.rarWhen the installation asks BT-dongle drivers click next and then copy these files to the right places:
wbtapi.dll
-> C:\windows\system32BTStackServer.exe
BTTray.exe
(Folder where you installed the soft)If the copying progress says that "Could not overwrite because the file was in use etc...",Task manager and proccess
Hi, does anyone know if the above crack works with the Belkin Range of Dongles as well??
I'm having problems with the PC suite only (with my 6600). I got it working originally and it was perfect. However, after a reboot the PC suite has decided that it doesn't want to see the phone, even though Mrouter does.
I've attached a pic of my desktop to show the weird situation i am in..
help!!!!
the link is dead!
pls help!
