Downloading Themes
3 replies · 3,516 views · Started 01 December 2003
Hi, I am trying to download the Climber.mbm from the Nokia Wap site, but when it gets to 99% downloaded I get an error message everytime which states "Unable to perform operation"!!!
Anyone else come across this, and knows of a solution. My 6600 is on the o2 network.
Ta....
I had the same error until I put in the DNS settings for my carrier in the Advanced Settings in the GPRS settings.
I am on Fido in Canada, so my settings wouldn't help you, but ask your provider for the DNS IP settings.
That solved it for me so I hope it helps you.
There were problems downloading poly tones over WAP, maybe one of those two things.
1. WAP gateway does not support downloading files the size of the theme.
2. In your GPRS settings the connection type needs to be set to permanent (or equivalent)
Neil
Hi Joolsca,
I have a 6600 on FIDO too. I tried getting mobile to mobile picture messaging working but can't get it going. I also have set up email and web access etc - and it is all working perfectly.
FIDO sent me the settings via SMS and I acepted them but they do not seem to work. The multamedia messages just sit in my outbox and finally time out - so clearly I am not connecting properly. I have had the techs on the phone but they can't solve it as it is not supported at the moment.
Did you get yours working?
