hi, i'm using my P900 with a powerbook running mac 10.3 panther. i sync my calendar and contacts via bluetooth over iSync, and it works fine.
my question for P800/900 users is this: i would like to install 3rd party apps (tracker, agendus, worldmate, and quickoffice, to be exact), and have read from the handango site i need a PC running the SE software to do so. have any of you successfully done so on a mac? if so, what is the process?
additionally, if any of you have used the above 3rd party apps and have any feedback or comments, that would be most helpful as well
many thanks in advance
