Help! I messed with c:\system\mail
7 replies · 2,325 views · Started 02 December 2003
First of all, Hi everyone! this is my first msg!
The thing is i've got a msg stuck in my outbox. what i tried to do is to delete all of the messages on my phone so i deleted all of the files on c:\system\mail.
Not a good idea.
All of my messaging applications died instantly. I managed to restore the normal SMS application by running Z:\System\Programs\Mailinit.exe. But the when i want to create a new multimedia message it says 'System Error!'.
Help help! what do i do!? 😕
I decided to reset the whole thing.. so i punched *#7370# and it asked me if i want to restore everything.. blah blah... i pressed yes and entered the lock code. phone was resete and asked me for time and date..
SURPRISE! nothing has changed. same background, same contacts and of course, same errors.... 😡
Anyone knows a better way to reset the phone so it will be the same as the day i bought it?
Thanks..
er hard reset your phone - you'll loose everyhting but might get sms function back again!
Thanks..
Try *#7780#.
uh, Thanks.. But the only thing that *#7780# did was to change my background and the hotkeys...
Originally posted by petr
Yes. Now try to repeat *#7370# again after it.
Hope this helps.
Nope.. same thing.
I think you need to visit your local Nokia Service Centre (list of them on support page of www.nokia.com). Your phone is under guarantee, so they will reflash/upgrade the firmware without charge - just say the mail options are not working. Make sure they can do it while you wait, by ringing ahead.
