In 3650 i resize image 174 x 132 and in 6600?
6600 image
a little bit bigger... but i use the same.... very minimal difference... hence i dont need to resize all my 3650 collections
ok, but i whant to now exacly what is the size thanks
176 x 134
Backgrounds (wallpapers)
7650/3650 : 174 x 132 pixels
6600 : 174 x 143 pixels
FullImage on Screen:
7650/3650/6600: 176 x 208 pixels
OpLogos:
7650/3650: 97 x 25 pixels
6600: 97 x i don't know
It's good to use the EXACT size for wallpapers and oplogos
because the phone don't make a good resize/shink/stretch of
the picture, so they look with some bad contour lines and artifacts
that are produced by the re-size and re-aspect.
Photoshop can do a much better work and you can notice that on
screen. So .. i suggest to use exact aspect and size almost for wallpapers and oplogos if you want to see it just right.
Use an external app on your PC to make a good resize and Crop
the image to keep the aspect, if you don't want to see bad stretched vertical or horizontal.
it's my opinion based on that i see, and i fully recommend this...
cya!
When i cut the .rm files in helix just can 176 x 144 what you thinks? i resize manual but he just put again.
Another question when i convert to .rm real one don�t have image just sound. thanks
