List with compatible BT-Sticks for 6600
8 replies · 2,797 views · Started 02 December 2003
Hello,
whats with the idea to make a list with working BT-Sticks with Nokia 6600?!
To admin: Please hold this thread on the top.
Serial Port Profile:
- Acer BT-500 with Widcomm 1.327 and Win 2000 won't work
- AVM BlueFritz! USB with 03.17.58 (Stack) and Win 2000 won't
work
Dial Up Network:
- Acer BT-500 with Widcomm 1.327 and Win 2000 works fine
work
Greetings
CKL
Am I right in thinking the stick may have a 100m range but you can only send to devices in which your stick is in range of them :/
So if your phone only has a range of 15m you cant send files 80m away from your pc as you need 2 way communication.
😊 No, the distance between PC and 6600 is only 1,5m.
Greetings CKL
