CAMERA FX Problem
10 replies · 3,267 views · Started 03 December 2003
Finally, probably one of the most awaited aps, 10x digital zoom, when I tested the trial version, it woulnt work on my P900 😞
Attachments: camera fx prob1.jpg
We're currently investigating the problem with CameraFX on some P900
phones. We plan to release an updated version of the software as soon as
possible.
Regards,
WildPalm Info
[email][email protected][/email]
Just got a response from them!
well, it worked for me, on P800 & P900 😃
but still it just crops the image and reduce the resolution without doing an actual zoom!
sure it's:
Phone: CXC162022 R3B004
Bluetooth: CXC12529 R5B
Organiser: CXC162021 R1C01
didn't update it yet, I'll try the onlnine update later!
I think you already have the updated one. I still have:
Bluetooth: CXC12529 R5D
Organizer:CXC162021 R1B01
CDA: CDA162003/8 R1A04
Do you have any problems uninstalling it?
I didn't uninstall it yet 😊
but the only problem I faced was after installing, my mobile hanged for 30 seconds with the same camera image, then I restarted, and it's all going fine (till now)🙄
but still as mentioned before it's just croping and reducing resolution, no actual zooming! although it has some nice features
