Read only Drive
1 replies · 1,641 views · Started 03 December 2003
On my phone, if I look at all drives in Fecxplorer I have a 'Z' drive which has a red line through it, which I presume denotes that it is read only.
The problem is, that I want to delete some files off that drive (especially to get rid of the really annoying operator logo!) - Does anyone know how to change the preferences of the drive?
Ta!
HI! there!..
Z Drive will never be a DELETEABLE DRIVE...
And you don't need to delete anything there...
And of course you can change the OpLogo to any image you want...
use FExplorer to do that... is a freeware app...
www.gosymbian.com
FExplorer app has an option on MENU/FILE/Set Image As Operator Logo ...
use that...
cya!
