Hey. What gives! I upgrade to WIN XP and now I can't...
5 replies · 1,928 views · Started 04 December 2003
send pictures from my phone to my computer via bluetooth!
Downloaded the current drivers from belkin and all seems ready to go!
I can send files TO my phone FROM my computer, but not the other way around. I get the "SENDING FAILED" error on my phone.
It worked perfectly on Windows 2000. Same drivers and everything. Are there other bluetooth drivers out there that I can try that would work???
TIA
-postingasadot
Just letting you guys know, I'm still having this problem. It still sucks, and I've asked around. No one else seems to have an answer for me either.
Gonna try a few things and get back to you.
This was a known problem for older version of the WIDCOMM stack drivers.It was fixed by installing new drivers or in some cases with a registry tweak.You can search for the registry tweak in the 7650 forum,but i doubt it will work.
There are a few possible solutions to your problem :
1. Check to make sure that all firewalls are disabled (incl. windows XP internal) this could be restricting incomming files via bluetooth.
2. If you still cannot send files to ur phone, i suggest starting in up in safe mode and than trying. If this works you know that the problem is software related.
3. Windows Update, possible outdated windows files regarding bluetooth
Try these and see what happens, hope it works
If not post back and will look deeper into it.
OK. I did find a solution which was to download version 1.3.2.7 of the Widcomm bluetooth software. However, I was stupid and didn't save the link to the website that was hosting the files!!
But I did manage to get the files myself! 😃
I just need some place to host if anyone's listening. But it WORKS PERFECTLY!
install pc suite
than install cdrom from bluetoothadaptor
than the pc will ask for restart
during restart you plug in bluetooth usb adaptor
then pc see adaptor and automaticly install final stuff
than you can open my bleutooth places
than u selct ''add bluetooth place''
in this menu pc will search and find 3650
select this
than you click on mrouter right mouse button and select com10
than you click with right mouse button on my bluetooth places
logo, right below on you screen
setup------configuration
change bluetooth serialport com3 in the menu client application
than in tab local services selct com10 lokal serial port
no you are finished and you can use it
-open now my blueooth places and double click nokia3650
push ok to connect on you 3650 and on the screen the
connection will fail.....but you will see its connected ...
you see a phone on mrouter logo in you right below screen
if it sometimes dont work jus get usb port out pc and put it back
than it will work again......
good luck
[email][email protected][/email]
