Calender alarm changes
4 replies · 3,178 views · Started 04 December 2003
How can I change the reminder alarm type and volume for the calender? The standard is very annoying. I sync my calender with Outlook. The links that I have read haven't been a help so far 😞
Other programs seem only to work with calender entries made from the Nokia 3650 and not those brought over from Outlook.
Thanks![COLOR=orangered]
Sorry to post a me too, but this exact problem has been bothering me for ages so I thought I'd add myself to show there's a bit of interest in the issue.
I'm going to do some more web surfing on this and if I find an answer I'll post it here.
Cheers,
Jase.
No luck guys. You can only change the calendar and alarm ringtone using a 3rd party software. Try SmartProfiles or Psiloc Extended Profiles Pro.
I prefer Psiloc's because it still let me have the vibrator working. However, the standard irritating and loud calendar ringtone will still come on for a second, followed by the ringtone that you selected.
For SmartProfiles, once you change the calendar/alarm ringtone, you lose the vibrator. It's a bug and had not been fixed for many months. I doubt it will ever be fixed.
Ok, thanks for that.
Do you know if either of those 3rd party packages can change it so the alarm only sounds once rather than repeating forever?
Cheers,
Cleve.
Thanks for the help. Do you know if those programs will also change the alarm settings for evnts brought over from outlook?
