Nice Display Light OFF
2 replies · 6,033 views · Started 04 December 2003
HI!...
I don't know if already somebody did this...
But i discover that if you put the Display option
to DARKER or very near to totally Dark... the Backlight
Display is turned OFF ALWAYS.... 😊 ..
That is a good way to save Battery on a Sunny Day i think...
or if you going Outdoor for a long time with good light conditions you can set it up that to DARKER and NO LIGHT will be used never... 😃 very nice battery save then!
And i notice that now the only thing that change the darker or lighter control is the light intensity .. so if you use less intensity i thing that the battery will really notice that 😊
even on average light conditions indoors is not needed the lighter display, it's logical because if no lights on ambience so less backlight is needed.
I set it up the Display control more near to darker for normal use..
cya!
Yeah i found this feature 2 weeks ago.
Its real amazing...
I put the light darker too,
and the batterie stay 50% longer...
(10 min. calls, 10 sms one hour gprs 4 surfing arround always 😉
one sync a day and a bit more infra (for the new themes)
But the light will be the biggest batteriekiller.
I always miss this feature @ the 7650.
S�mi
