Acces Points Problem
1 replies · 2,344 views · Started 04 December 2003
Hi!
I have a very bad problem.I cant use any acces points for MMS.
I already set them up in the Acces Points menu but when i go to Messaging-->Settings-->Multimedia Messages and from there i try to use the MMS acces point it says NO ACCES POINTS DEFINED.
Why the fuck?I now 100% that it is defined and GOOD.
PLEASE HELP
Are you sure that you have a access point set.
Check...
Messaging>Options>Settings>Multimedia Message>Access point in use
This should contain the name of the MMS access point given to you from your provider. Dont forget that MMS runs over GPRS so you need to have that enabled on your account and have a GPRS access point for MMS to work (Do you have a little 'G' under your signal strength indicator?)
The simplest way of setting this up is by calling your service provider and getting them to SMS the settings over to you. If you are in the UK and want to set the access points yourself, the settings for most service providers can be found here
GL HF 😃
