Anyone ever tried to sync a large contact list (over 1500 entries)from Outlook into the P800? I've noticed that you can't reliably sync more than 150-170 contacts at one go or the syncing will hang and the Contacts.cdb then becomes corrupted.
I've tried this with Outlook XP on Win2000 & WinXP with the same results. PCSuite 1.0.0, 1.5.1, 2.0.1 same results.
Anyone have the same experience?
Redd
I gave up on Outlook for Contacts and switched to Lotus Organizer (for Notes and Contacts). I have had zero problems in the month I've had the P900.
I have a contact DB in outlook of 900 contacts since march so I have use one of the first version of PC Suite. I have had very few sync problems. Sometimes a change in a contact was not detected.
SymbianAdvisor wrote:I gave up on Outlook for Contacts and switched to Lotus Organizer (for Notes and Contacts). I have had zero problems in the month I've had the P900.
How do you set the P900 to sync with Lotus Organizer?
