I have downloaded the 11 page pdf specifications and there is no mention on text input methods available.
Does anyone know if the Sendo X has T9?
I was looking to get the Nokia 6600 but it's a bit wide, and the keypad is too small and cramped.
Also I read somewhere that the Sendo X will allow user installable firmware updates, that's a BIG plus over Nokia - I had to make many trips to a Nokia Service centre in the past, and that's 25 miles each way.
Taken from the manual...
You can enter text and numbers on your
phone using the keypad. Your phone
supports three input modes for entering text
and numbers:
1 Multitap - normal text entry mode
(uppercase and lowercase).
2 T9 - predictive text entry mode
3 Numeric - number entry mode
Will
Where can I find the manual, another post mentioned this was on the Sendo site, but I cannot see it.
Do you have a link?
Or can you email it to me at
mrzippy AT encodinginfo DOT org DOT uk
thanks
Neil
Does it predict punctuation like Nokia when you press key 1?
Does long press of button produce numbers like Nokia?
I see space is on key # from the screen shots, I could just above live with this, but key 0 would be better like Nokia's.
Sorry I just love to text and am a Nokia T9's implementation addict, and don't like to much change 😊
Well I'd have thought it isn't so much as Nokia's T9 system but Symbian OS T9 system right?
So shouldn't it have the same features on all Series 60 phones
user manual was online for a few days... they took it offline again, right?
yes they took it off for some reason
the manuals are still online..... just d/loaded them.
