im not really good with computers so i dont really no how to do everything with my n-gage so first off can you put songs directly on the n-gage memory or do u need a mmc card and secondly to put stuff on your n-gage or mmc do u need pc suite cause i cant get my pc to read my n-gage when its connected via usb.
any feedback tips or pointers greatly appriciated plaese write back.
well, you must store your mp3's on mmc. because n-gage has got only 3mb internal memory 😉 So just store your mp3's on mmc. there was a thread how to put things on mmc. Just find it. 😉
Hi
N gage pc suite doesn't pick up mine either!
When you've got your phone connected via usb,go to my computer,it should show you're phone as an extra drive(F on mine) open that then drag and drop you're mp3's into the sounds folder.
I'd reccomend buying a 128mb card to get a reasonable amount on.
Hope this helps
