Associating Opera with URLs
8 replies · 2,025 views · Started 06 December 2003
Anyone know how to associate URLs with Opera?
I want to open web links from Jotter etc in Opera, but it always defaults to the built-in browser.
That's because it is not possible.. All URLs are associated with the default browser.. That's how it works on pcs as well.. They only obvious way to do it is to change Opera to the default browser.. However, that is not currently possible..
That seems like a fairly big flaw...
Opera doesn't have "Bookmarks", and you can't 'click' on a URL to open it in Opera, so the only way to use Opera seems to be to type the address in manually, or pick a URL from your History.
That also means that you can't clear your History out periodically, or you'll be back at Square One!
Not ideal IMHO
Originally posted by GhostDog
Maybe someone can write a small app that can change the MIME settings?
Oooh, yes please!
I don't know Java or C, so I'm in the hands of a generous programmer with some time on their hands!
(While they're at it could they write an app to mark all emails as read for a specified Mailbox? - I only download headers for my work address, so the ones that aren't urgent just sit their as unread)
Errr... it does? Where?
I've only recently installed it, but I can't find anywhere to add them or to select them from a list.
Where are they?
(I've got the version that comes on the P900 Application CD)
Open a web page, go to "Web" - "Add bookmark".
And once you have added a bookmark, it will show up in the default view of Opera. You can also edit and send the bookmarks as e-mail/MMS/IR/BT by clicking on the little green icon in front of the bookmarks.
