MP4 player?
16 replies · 27,188 views · Started 06 December 2003
Is there a way to play MP4 files? Tithout to convert them into rm or 3gpp.Maybe there is a player for 6600 that can play MP4 video.
If anyone knows of that please HELP ME
Yes it works.Thanks
But if i play videos recorded with p800/p900 do they have sound on 6600?
Or not?
HI!...
3gp don't mean Mp4 always...
3gp can be encoded using:
- MPEG-4 Format (this format is not supported by RealOne player
or
- H.263 format (not mp4) 6600 read this file only by default RealOne player
the versions for 3gp are 4.3 or 5.1
cya!
Originally posted by AEFOX
HI!...
or
cya!
RealOne Player in 6600 supports MPEG-4 VSP.
HI!..
i was testing different formats to play on the RealOne Player..
I compare to play 3GP (using MPEG4 codec) 176 x 144 160kbits/seg with audio at 8000bits/seg.
and 3GP (using H.233 codec) 176 x 144 160kbits/seg with audio at 8000kbits/seg.
I saw that RealOne LAGG a lot!! with MPEG4 at 160kbits with audio... if you encode video only.. not lagg and good quality..
BUT! 3GP using H233 codec.. is much more fluid video, same quality than mpeg4 ... not lagg WITH AUDIO...
SO!.. i keep using 3GP (h.233 codec) and good bye mpeg4.. (almost on this phone with RealOne Player)
BTW! 3GP (H.233) is the format used by Video Recorder that came with 6600 and the supplyed for the 7650...
and BTW!.. PVPlayer.. LAGG MORE than RealOne at 160bits/seg videos, even using H.233 or MPEG4 codecs...
cya!
HI!..
cya!
Try to use a bit lower bit rate for video, for example 128 kbit/s.
I know that with lower bit rate the lagg it's gone..
but lower bit rate... means lower video quality...
So, that's why i am using H.233 .. because you can use 160 kbits.. and get more quality than mpeg4 at 128kbits for example.
thanks!
cya!
thanks!
cya!
OK, why not encoding the videos with Helix Producer Pro 9+??
The quality is MUCH better than any 3GP file i have seen.
I compared the video freaky friday on 3gp and RM, equal settings...
Just watched LOTR 3 on RM (>97 MB), GREAT Quality so far ...
