(NEW) Christmas nokia 6600 theme
16 replies · 13,324 views · Started 07 December 2003
wow !!!! it really come at the right time !! i am look for some themes like this!! u are great!!
This is the best theme ever! Thank You! I want more... And the best part is that the theme is a .sis file, easy to download.
Ok... this is my first theme
it's called BLUE v1.0 (digital clock not skined yet)
If somebody want this Theme, send me your name and your email
to: [email][email protected][/email]
i'll send you the link to download
Hope you all like it
Cya!
check this out
its my new theme i will rls it soon
aqua 1.0
Attachments: aqua.jpg
OK!.. that nice..
your welcome!.. i create your down bar buttons 😊 .. and you change the color of it
keep mixing themes!.. hehee!
the Top Bar is a new color from Crystalized theme 😊 hehe!
nice work!
cya!
thanks dude
by the way the header is not from Crystallized go take a good look at it
and the down buttons u can make them by aqua action that u can find in any photoshop website . bbye
hehe! ok i know that how you can make it..
but! come on! 😉 ... same buttons, same place, same coordenate, same crop, same length, same distance?.. 😉 ..
say the truth i don't care.. but you use my buttons and chage the color right?.. more fastest and easy way.. 😉
hehe!
cya!
cool down dude 😛 . i didnt said that i didnt use them i did use them and sorry for not taking you premmtion
sorry for may bad english
No problem Dude! 😉 ..
Just Checking the honest of some people here hehehe! 😃
cool!
HI!..
i notice something about the Wallpaper, Gallery app and Themes use...
If you make a theme when you apply and appear the
question: "Replace the Wallpaper too?".. if you say YES..
OK you got the wallpaper... BUT!.. that wallpaper look a little different than the original wallpaper image... i think that
theme app convert the wallpaper to a 12 bit image.. because you can see a gradiation colors very easy (separated bars of colors, without dither).
I notice this on my wallpaper of Blue .. the white (grey scale) on the background looks with less gradient colors...
But if after i change the theme i assign again the wallpaper only with the original bmp image (24 bits)... look much better.. no gradient bars.. more solid... and even BETTER than when i see that image on the GALLERY APP... i don't know why... but only when you use any image like a wallpaper setting it directly from the option SET AS WALLPAPER ... then you really see the image with the MAX QUALITY EVER, but only on wallpaper place.
So i think that THEME app and GALLERY make a down convertion to less colors in order to load the image faster each time you go to main screen or you are seen images on the Gallery sacrificing the quality.
you make this test and you will notice that...
you can see it easy up there i put that main screen shot .. i see it just like that ... only if i assign the original bmp image.. compare that image of blue wallpaper with the installed theme wallpaper .. you will see the bands at the background on yours
cya!
Hey All,
This is my first attempt.
Thanks to whoevers buttons I used and the clock. Modifying my own one as we speak.
Ian
Attachments: coolice_louise_002.jpg
sorry for this but I'm just a new user of nokia 6600 I am just going to ask why i can't seem to use the theme for the nokia what kind of file is it? and where can i download some themes please....
Thanks!
