Hello,
A new users question, apologies if this has already been covered. I did search but have not yet found an answer.
I want to know if it is possible to re-arrange the order of shortcuts under the "Flip Open" application list ? Furthermore is this possible under the "Flip closed" application list which comes up when I hold down the applications button ?
Or will I need to buy some kind of third party software such as Tracker to achieve this ?
Many thanks
Robin
No, not possible, you can only arrange them by putting them in folders.
An application such as Tracker is a necessity IMO. It has many other great functions as well. I'd suggest you give it a try.
Raven,
Many thanks for the quick reply.
Out of interest how do I go about putting shirtcuts into folders. For example I would like to make a games folder on my drop down list and an office one for viewer, quickword etc. etc. any tips ?
Robin
In the Applications list menu you click "Applications" - "Set folders" and then you can click "Edit folders" to add/change names etc., and to move to applications around into the various folders you simply click the app you want to move, in the "Set folders" view.
