1.is there a reycle bin program for it?
2.is there a program to restar the device?(just like the 9210)
there was a 3rd really good question but dont remmeber it
1) Make a folder called Recycled and move the files there 😃
2) You can restart the device with many applicatons,first that comes to mind is FExplorer.
well so far u didnt answer any question😕 😕
i meant recyvle bin like windows
and restar not through seleq or feexplorer but a program that its only job is to restar😞
thanx for trying
Well,recycle bin does exactly that,moves the files to the recycled folder.You will notice when you manage the files on your MMC from your PC that deleted files are stored in the recycled folder,if there is enough space on the MMC.IMO,on a very limited storage device like the N-Gage this program is not very usefull.
Maybe some undelete application that will store the files with some compression algoritham so they won't take up so much space.
And for the second question,i think your are nitpicking.If you really need a separate restart applicaton,why don't you code it your self.
ok???😕
Ismail, GhostDog said the best way to have a recycle bin : create a folder and about restarting.... GhostDog is right too 😃
yeah i know wat ghot dog was saying
it just wasnt the answer i was looking for(alwys hoping for more)😉
