GPRS Settings on Vodafone...
3 replies · 40,738 views · Started 08 December 2003
Does anyone know how to set up GPRS (for web surfing and picture messaging) on the 6600? I've called Vodafone customer care, and they don't have the settings(!), so sent me the ones for the 3650, which don't seem to work properly...
Thanks in advance for any help.
VodaFone on 6600 :
First of all send yourself the 3650 MMS / GPRS settings to yourself from the nokia site then amend as below.
MMS settings
Press the menu key
From the main Nokia menu, go to Tools,
Then Settings,
Then Connections
And then Access points
Select the correct Vodafone Live connection which contains the MMS settings
There will be two Vodafone Live! Access point options, the upper one should contain the MMS settings (this can be checked within the settings by going to the homepage setting and ensuring this shows as http://mms.vodafone.co.uk/servlets/mms).
Highlight the first Vodafone Live! Access point and select this using the joystick.
Then select Options and Advanced Settings.
Now ensure the following configuration:
Phone IP address: automatic
Primary name server: 0.0.0.0
Second name server: 0.0.0.0
Proxy serv. address: 212.183.137.12 (as the Nokia's default is "alpha" mode, the user will need to select "numeric" mode by pressing and holding the hash key - the indicator at the top right of the screen will then change from abc to 123. To insert the "." character simply use the hash key in "numeric" mode)
Proxy port number: 8799
Please Note: It is recommended that the Connection name is changed from Vodafone Live! to Vodafone MMS so it is clear to the user which settings the profile relates to. This can be done by highlighting and then selecting the Connection name using the joystick. The connection name should then be highlighted. At this stage hit options, then change. Edit from Vodafone Live! to Vodafone MMS. Once complete select this using the joystick. Hit back and you will return to the Access Points menu.
GPRS/WAP settings
Once completed you will need to amend the GPRS/WAP settings. If the user has not renamed the Vodafone Live! access point name, this should be presented as the lower Vodafone Live! option within the Access point menu.
If the user has renamed the Vodafone Live! access point name to Vodafone MMS the GPRS/WAP settings will be presented as the upper option within the Access points menu as Vodafone Live! (this can be checked within the settings by going to the homepage setting and ensuring this shows as http://live.vodafone.com )
Highlight the Vodafone Live! Access point and select this using the joystick.
Once changed hit back to return to the normal settings.
Please Note: It is recommended that the Connection name is changed from Vodafone Live! to Vodafone GPRS so it is clear to the user which settings the profile relates to. This can be done by highlighting and then selecting the Access point using the joystick. The connection name should then be highlighted. At this stage hit options, then change. Edit from Vodafone Live! to Vodafone GPRS. Once complete select this using the joystick. Hit back and you will return to the Access Points menu[/b]
what country is this for? does it work in the uk?
if not, does anyone know how to full internet on my 6630 on Voda in the uk?
thanks
geoff
