Computer won't detect my n-gage
6 replies · 2,481 views · Started 08 December 2003
I tried connecting it to my pc using the usb cable they give you... The usb image comes up on the phone and my computer says "New Hardware ... Nokia N-gage"
When I search for drivers I can't find any 😞 So the software on the n-gage cdrom won't work. 😞 How can I fix this?
i had this problem if ya runnin windows XP just run it through the update and try again it worked fine for me!!
Tried it on xp and It didn't work... So installed 98se and still had the same problems... Anyone got the driver I need to make this work?
Wat worked for me was intalling all the software that came with it, but not using it. U sure it doesnt create a removeable drive in my computer?
yeah with mine - it just did the normal "found new hardware" - then "installing new device" then "Nokia N-gage" then "your hardware is ready to use"
I didnt have to install anything it just happened.
Do you only have one USB port - try using a different one, sometimes this can be a problem. Also some settings in the Bios can afect how the USB port works but I dont have details...
