how to sent sms between 6600 to 6600 or p900 using bluetooth?
6 replies · 2,061 views · Started 08 December 2003
ned wat program or method?
thx.
or is there any realtime chat using BT for all BT mobile?
need wat program? too
if i use a 6600?
thx.
You have to go Notes, create a new one and then press OPTION > SEND > VIA BLUETOOTH, select the target device and that's it.
If you wanna chat, then install it.
But if you wanna send a msg via BT, create a new note and send it. 6600 will recieve it as a note, and the P900 will recieve a txt file which it can view 😉
Unplugged wrote:Just out of intrest why would you wanna chat with someone 10m away from you...
Thats just sad :|
for example you're eating at MCDonald's and there's a beautiful chick at your back or at the next table and your too shy to approach that girl, i think bluetooth will be helpful with that kind of setup
believe me guys.. i tried this a lot of times..i mean lots of it.. and believe me.. you will meet chicks with this kind of tactic.. it kinda wat the chicks dig.. i actually dont know.. probably a case to case basis? 🙄 ... 😊
