Full Screen = Realone Player - How?
11 replies · 6,585 views · Started 08 December 2003
Nope not yet. Im sure theyll be a 3rd party app to do just that.
There is one currently, but it requires converting the files to .mo rather than .rm.
Mobiclip Everything is free, which is pretty cool, but theres alot of conversions involved and the average file is about 3x larger than .rm. The software itself is beta, so dont expect anything amazing form it just yet.
Yea it does but it wont play .rm. Maybe therell release an update with the capability to play em.
Real Media has the best sound and video compression ive seen yet. A lot better than 3gp.The video doesnt pixelate when changing scenes. I can also compress a 5 meg mp3 into less than 2 megs and have the same sound quality. The only problem is that nobody on this forum can seem to help me with the N-Gage not recognising the headset and causing the volume to not work properly on Real Player.
I may have missed your post, but i had the same problem with the headphones when listen to music and stuff. Turned out to be faulty headphones. Fortunately i was able to nick some more from work. The wire seems to beable to snap quite easily, especially when shoved into me bag, cant understand why! 😃
Also ive heard through the grapevine that there are two new projects underway, to create a fullscreen app or patch to enable realone to play fullscreen!
One lad told me he was build his own app to play em, other said he was in the middle of creating a patch for realone.
Dont get ur hopes up yet thou, cus you know wat some sad little people are like.
Ill let yall know as i hear more from em.
thanx SAbz911 for this info.. i will be waiting here to hear about these 2 from you 😃
Did a search on this topic but found nothing - what problems do you have with headset and r1p?
My problem was the sound kept going from stereo to mono etc. but turned out to be a broken wire in the headset. SOmetimes i didnt get any sound at all.
