7650 Problem
8 replies · 2,617 views · Started 09 December 2003
Hi all,
I'm facing this problem with my Nokia 7650 which just surfaced a week ago or so.
Occasionally, I would get this message on my display.
App.Closed
MediaServer
E32USER-CBox33
After clicking ok, I can continue as usual. Not much problems caused but the opening of MMS, or savnig of images can be exceptionally long (about 1 min) at times.
Any one have any ideas what is happening to my phone and how to get rid of this msg?
Thanks... 😊
dear friend...i think u have to update ur mobile software..if u already done that then try to put the old version and again update to the new version..then directl after u finish all that(plz remember that u have to format the phone)go to nokia.com and go to support try to find MMS and then just follow the steps..and hopefully it will work..
Phone has already been updated..... with the latest firmware - V 5.06. If I have to reinstall the old one, then reinstall the new one, I would have to go to Nokia Service Centre again and since my phone is no longer under warranty, I think I have to pay a hefty fee.
Would a soft reset help matters? What does a soft reset do to my phone anyway?
man ...f u dont want to do so ..i'm telling u that u will have to face this problem day and night...i mean u have to do the software thing..]
and for the mms u already said that u r facing some problems wiht ur mms setting ...just go to the nokia site and just follow the steps for that.........
and wish u the best..😉
i'm also experiencing this kind of message:
App.Closed
MediaServer
E32USER-CBox33
do i really need to upgrade my software? what if the latest software version has bugs?😞
u r right ..it might had some bugs..but so far no one experience anything on that issue...
but i will update if there r any....but belive u have to do so..ok..😉
App.Closed
MediaServer
E32USER-CBox33
do u know the latest software version?
