is there a way to change the folder icons? also, i use photoshop and i cant seem to get rid of those jagged edges whenever there are curves in an icon. any tips?
To the theme makers...
HI!...
I don't know how to change folders icos.. like i don't know how to change any third party apps 😞 ...
The edges can't be smooth because the mask can be only black and white not smooth edges are conssidered...
it's sad.. but we can live with that i think... 😊
one easy way to get better look i think is leaving the background for the icons on white for example, or any flat color and then use that BG color when we create the icons, so we can use smooth edges and they don't need mask and will match with the whole background on Menu..
cya!
great tips there bro...thank you! 😊
im testing the theme editor from nokia, running on winxp, it is very slow!
