N-Gage not compatible to all series 60 software???
4 replies · 3,110 views · Started 09 December 2003
hi there,
i purchased my n-gage last thursday and am very happy with it, although I am facing the following problem:
I�ve tried several series 60 games, like Snails for example on the n-gage.
While installing it says that the software might not be compatible witht the device, after trying to boot the installed game I get an error message.
On the website of pdamill.com it says that snails is compatible for series 60 phones (that is the 7650).
So, my question: Can it be that not all games that work on a 7650 work with the n-gage?
Prince of Persia - Sands of time from Gameloft does, without any problem!
Besides, does anybody know how I get a MP3 file to work as a ringtone? does it have to be converted to .rm file format?
thanks for your replies,
greetz,
efco
The only reason I can imagine some software wouldnt be compatible is if it uses functions to do with the camera or somehting which the N-gage doesnt have...
As for getting an MP3 file as ring tones - simply copy the Mp3 to the Memory card and go into your profiles and the file should be available just like any other ringtone....
This isn;t a problem with the NGage, or the software, but the program used to create the installation SIS package. It's not setting a flag correctly for install (I can name quite a few apps, including my own) tha have this problem. Rest assure the apps are compatible, you just override this setting by installing the SIS FROM THE PHOEN (so beam or BT it over to the Message Box)
so, what do you mean know?
can I run this apps or not? if yes, how?
The problem with Snails could be that it can't work if installed on MMC.As you know it was originally designed for the 7650 which doesn't have an MMC slot.Try installing in phone memory and as Ewan said install it from phone and ignore the "might be incompatible" message.
