Tube Boston map won't load
1 replies · 2,160 views · Started 09 December 2003
Are there any other Tube users out there that have trouble loading the street maps? The Boston subway map works fine but when loading the street map even if I close down all other apps and compress memory I get a dialog saying "Memory is low. Close all applications to free memory?" If I click Yes and try loading the map again the same thing happens. The only way it will work is if I reboot the phone and load the map before doing anything else. It seems that if I have anything less than 8Mb of memory available it won't load.
Thanks,
Alex
I used to have the same problem, and thought that it was a program bug, but after I formated my device and resored my old stuff, it started to work fine..
guss it needs lot of memory, so u don't have to install any program on the C drive to get it work 😞 but still it's really worth it😊
