Hi All, i'm a newbie so go easy plz!
Just got a 6600.
What is the best program for getting my dvds to the mmc in the best quality but not to over the top in memory space. (Post Links)
i got a dvd drive on my pc & 128 mmc card.
Also can you play movies full screen on 6600?
If sumone could send me an indepth guide about putting dvds on mmc for 6600 in good quality could you pm me, and i'll send you my mail ad, or look at my stat page?
Many Thanks, James.
you need a program called DVD to AVI which will convert your encoded DVD files to AVI's.
You can then take your AVI's and encode them for packet video from www.pv.com
if you want to view full screen then best use PV player also from www.pv.com
searching google should find you everything notlisted here
Euther than or use Helix to convert to RM but you will lose the Full Screen 😞
can anyone tell me what settings i should use to convert my mpeg or avi in Helix Converter. The file which i have is of around 45 MB and is a music video but while converting it gets reduced to around 9 Mb. can't it b further reduced coz i have seen other videos which are lesser in size and is of almost same length as mine music video.
Thanx in Advance...!!
Siddharth,search the N-Gage forum,there is a guide posted there.
