ey guys, i need your expertise here. i installed doom for p900 and to my dismay, it still needs a doom wad file to run it. since i don't have the luxury of a big memory, i decided to uninstall it. alas! an error message appeared and i can't uninstall it. i tried restarting the phone but the problem still persist.
what should i do now?
I think you should search the Symbian Gaming forum,maybe even the p800 forum.
Try reinstalling EDoom, and uninstall it again..
If that doesn't work, use a 3'rd party file manager to get access to the system files, and delete EDoom from the \System\Apps directory.
Also, if you have the WAD files installed, you can remove them from \Media files\document\DOOM.
sorry for the very late reply guys.
hmmmm...still no luck. i did installing again doom but a message appeared saying access is denied.
i did try editing the system folder from a card reader. but it brought more chaos than remedies. my ms died on me and can't be accessed anymore from my p900 after deleting the edoom folder and edoom.sis files.
argh! need help guys! and what file manager apps do you suggest...
I suggest using PC File Manger from Epocware
u'll find it so useful and easy to work with, but still slower than a card reader!
