Transferring files to P900
3 replies · 2,334 views · Started 11 December 2003
Hello there! Will someone please help me transfer files to my P900? I have some files (images, documents, music, videos) in my PC which I want to transfer to my phone and I can't seem to find out how. Will someone please give me detailed instructions on how to transfer files to my P900? I shall appreciate it very much.
Thanks!
Friend,
You can use PC Suite for P 900 software which can be installed from your P 900 CD or buying Card Reader which can read 6 types of Memory Card (MMC, CF, SD, Memory Stick). Afterthat you can transfer all files to Memory Stick as using Window Explorer in Window. Actually don't use your memory phone to save all applications, but you better use your Memory Stick. Sorry I can not give the detailed steps but should you want to ask more, you can e-mail me at [email][email protected][/email].😉
Best Regard
On the desktop, you will see an icon that says 'my P900'. Double click on this and you will see the folder structure for your phone and memory stick...then simply copy and paste the files to the appropriate folder...
Hope this helps...
Cheers
Nick
