Im after Barthezz - On the move Midi tune as i want it on my phone, Ive dredged the net and even tried making my own , if anyone has seen anywhere that has it i would be a very happy man !
Im sure many other ppl here would like it too !
Cheers 😊
Cheers 😊
www.SingLouder.com
might have it, though it requires a small fee 😃
As far as I know GS is General MIDI, XG is Extended MIDI,
not too sure which is supported within the 7650, though most likely GS.
Try this link...
http://singlouder.com/demos
Right-click and "Save target as" 8)
Or use WebMiner and point it at the same path for it to download the whole lot for you.
The only problem is that you have to manually rename each file with the appropriate track title. 😃 Having said that the demos seem to be quite good lengths for ringtones!
Thanks singlouder.com!
http://singlouder.com/demos/165%20GS.mid
that is 😃
