when i send mass by infra from laptop to 3650 the batry finshed and shit down .. after that the main manu not seen ..
phon masseg say ( close msgff ) YES - ok
i remov mmc memory card tha phon working ok .. without card
what i can do .. ?
what i can do .. ?
What can you do? For a start you could re-post it using proper English! What does the phone message say? 😕
It sounds like some data became corrupted in your MMC due to loss of power.. I would recommend getting an MMC card reader( or just borrowing one from someone) to format it and then install everything you had on it again...
I just hope you have a backup of your old files,otherwise they'll be gone forever...
Cheers
Raygun
