I've searched the forum for Time problems/errors and read about a lot of people having problems with their clock setting suddenly changing (time +/- X hrs).
I have a similar problem:
My calendar items are all one hour off, but the PC&P800 times are correct. Extremely annoying!
Example: time is now 08.00 (pc and p800 shows this), meeting at 09.00 in Outlook is converted to 10.00 in the p800.
Any ideas on how to solve this?? 😕
I use PC suite 1.2.5.0, phone FW R2F
Rgds,
Carl
Originally posted by choeg
Hi,I've searched the forum for Time problems/errors and read about a lot of people having problems with their clock setting suddenly changing (time +/- X hrs).
[B]My calendar items are all one hour off, but the PC&P800 times are correct
Example: time is now 08.00 (pc and p800 shows this), meeting at 09.00 in Outlook is converted to 10.00 in the p800.Any ideas on how to solve this?? 😕
Rgds,
Carl [/B]
It's probably either a difference in time-zones between the phone and PC or (moe likely) one is set to Daylight savings and the other isn't.
Time zones are the same (GMT, London).
Summertime/daylight svg:
P800 - no boxes checked (since no summer time at the moment)
PC - "auto adjust clock for dayl saving changes" is checked
.. will try to change this and see if it helps, but I doubt it since the times are displayed correctly in both the p800 and the PC.
It is just the calendar items that are off!
Thanks for the suggestion though.
Nope... the daylight savings change didn't work.
THis is driving me nuts!! the clock is totally correct on the phone, but the frea**in calendar is off.... GAAAH
Nope... the daylight savings change didn't work. THis is driving me nuts!! the clock is totally correct on the phone, but the frea**in calendar is off.... GAAAH
Have you tried setting synch so that the phone adjusts to the same time and date as the PC?
Yes.. I've tried that too... doesn't work.
