AppForge Booster & ISMS
3 replies · 2,226 views · Started 12 December 2003
I purchased and downloaded ISMS from Handigo only to find out that it requires another program called Appforge Booster to install!
Anyone come across this, now what it does etc....?
Appforge booster is the platform used to devolop the software you are downloading thus, you will need the appforge booster progarm to make that program that you like run. Appforge booster is free and downloadable at handango also.
Appforge takes up lots of space so make sure you have lots of space.
On the '800, AppForge was reputedly unstable -- loads of complaints.
Anyone know if the new version / version for P900 is better?
the version of app forge on the site v4.0 is the same for p900 and p800, upon installing, you can uninstall the "more apps" to free up some space
