Question to the GPRS-symbol
7 replies · 2,075 views · Started 28 August 2002
Hi there,
I have a question on the GPRS symbol. The small "G" at the left upper corner of the screen is sometimes without frame, sometimes it is framed and sometimes it flashes. Does anybody know what this means? It isn't in the manual.
Thx for your help
G on its own means you are connected to the GPRS service
G in a box means the connection is active
G with a line through it means GPRS is not available at the moment (when you are sending SMS for example)
Not seen it flashing yet - don't know about that one
[quote="Freddie666"]Thanks! - I guess that flashing means it seeks a connection - but am not sure 😊[/quote]
Yeh your right - flashing is seeking connection
Sorry didnt see the other person before this reply had confirmed it
