BackLight in Nokia 6600
13 replies · 4,111 views · Started 13 December 2003
Try searching......
take a look at a program called 'torch'
and also extended profiles I think it's called, if not someone will correct me 😉
you can play with the backlight with those.
Torch turns the backlight on perinatly with a white screen you cant do anything with the phone meanwhile its about as much use as split condom :/
Extended Profiles Pro has 3 options for Backlight AFAIK:-
1. Normal- (As Per Phone settings)
2. Always On
3. On when charging😞
Guys
Where do you get hold of Extended Profiles Pro? I take it it's not already on the phone.
Cheers
Kav
I found with "torch" that if you leave it runing in the back ground the screen light stays on.
How much of a hit does the battery take when leaving the back light on all the time?
Does it reduce the screen life (pixel killer?) as well?
I would imagine the battery drain would be quite something if left on all the time!
I cant see it killing pixels tho.
