DivX player?
5 replies · 10,299 views · Started 13 December 2003
crystal player might do that, but i'm not sure. I'm not sure what the point would be, as divx files would take up loads of room, and mmc cards aren't that big anyway, and the quality would be worth it on such a small screen.
You could just resize or re-encode the divx file to fit the screen.If you do this you will notice that the size of the divx file has decreased a lot,so there wouldn't be any problems with storing a whole movie or two on a 128 MB MMC.
I had plans of developing something like this,there are divx players for Palm OS and PPC but i haven't had the time or the funds to update my programing skills.
I wonder how the 120Mhz CPU (Sendo X) would cope with DivX routines? I suppose with the file resolution being that low, then it shouldn't be too bad
I don't think it will have any problems at all.My 7650 had no problems with decoding high bitrate(up to 200000 bps) 176x144 3gp videos.
