Nim files to real player files
2 replies · 3,434 views · Started 14 December 2003
Hi room
Long time I guess !!
Does any one have an idea how to convert nim files to real player extension
Tks 😊
As far as I know that's not possible.
You have to find a way to convert mediafiles to the real-format, but those converters will not support .nim files, so you have to find the original files used to make the .nim files, and then convert them to the Real-format.
Ginzy9210 wrote:Hi room
Tks 😊
Hello GINZY
I am a new user !!
I need to playback the files recorded on a camera mobile such as nokia 6600
I got it copied onto my 9210i but the format is not recognizable
You seem to have achieved some sort of break thru
If possible do let me know If you have any file encrpter s/w for the 9210i
Thanks in advance
MAG 😉
