Changing MMC. Please Help!
1 replies · 1,352 views · Started 14 December 2003
Hi All!
I hope someone can help me with a small problem i have. I bought a 6600 and it came along with a 32MB card. I've installed some games and applications on it. Now i'll be getting a 128MB card so i can use that only for games. What i would like to know is,
1. Do i have to install some system software onto the new MMC so i can use it
or
just use it normally and reinstall all the games? (I dont have a card reader)
2. Can i switch between the 2 MMCs one for normal daily use and one when i want t play games without any problems?
I definitely dont want my phone to crash so i really hope someone can help.
Thnaks a lot in advance!
Cyberelle
Hi.
Maybe you need to format the card before you use it, otherwise I don�t see any problems that may come.
You should be able to switch between 2 mmc cards without any problem. Though I can�t guarantee it...
BR
Anders
