hi
i wanted to know how can i make .class applications and games work on my 3650?
is there anytool to convert them to jad or jar format?
thanks
working with .class files
I'm not familiar with java but for starters download the SDK and Documentation from www.forum.nokia.com
you don't use those .class files for themselfs..
I'm almost 100% sure that they came bundled up in a .zip file,right?
The thing is that this .zip file just needs to be renamed to .jar
.jar = java prog... 😉
So,just zip the files back up (unless you kept the original .zip file),mark it,press F2 and give it a new name : <name of the prog>.jar
After that,send them to your phone and it will install automatically.. 😉
Cheers
Raygun
