Cool program -> Mobile Pluz
8 replies · 4,669 views · Started 14 December 2003
pretty useless if you ask me. You cant even call it a theme, just a little animation. Besides, you can use FullScreenCaller.
My 2 cents
I like it.It need work though,more events and more themes.I don't like that the new message pop-up and probably most other default pop-ups hide a small part of the animation.
Hello guys!
It's good to be back here. Unfortunately, the link is not working. =)
Where else can I get the file? Please let me know.
I loaded the app which looks quite cool, but it seems to get in the way of answering calls (ie when you press any button to answer, there's a delay before the answer kicks in - which may be enough to divert to answer phone/whatever).........
So I've removed it.
With some software versions if seems that the processor if fully used when a call comes in than the animaion takes quite long to load. A fix here for is to set the animation time of the incomming call to 0. For borken links go to http://www.pocketdownload.com
and search for "mobile pluz"
later
