I have set the Autolock function to activate after 15mins. So as it had been left longer than 15mins it had locked itself like its meant to.
When I came to it the phone had 3 missed calls. It had the "3 missed calls" message box on screen and the option under the left button was "Unlock"
But no matter what I did or pressed it wouldnt unlock. The "3 Missed Calls" box kept popping up over top of unlock code box.
Only way to sort it was to take batt out.
Anyone else had this or similar?
Cheers,
Mike.
i have test it out now.
But it works correctly @ my device.
first the poup appears, but at the left softkey is the option: unlock.
If i push it, the new popup 4 the securitycode appears.
(Its cool, that the possibility to take on a incomming phonecall even with the locked phone.)
sorry my bad english
S�mi
I've been experiencing the same problem with the autolock
feature. I set the time out to 5 hrs so that the phones locks
itself at night. In the morning if i have new messages and/or
missed calls the list(s) appear on the phone's standby screen,
and the left button says "Unlock" and nothing works after
that. It keeps asking for unlock and doesn't do it when I press
the unlock command button.
I think this is a BUG ......
I've turned the autolock feature OFF until i can find out whats
wrong.
Glad its not just me then.
I often get txt's while phone is locked and it unlocks fine. Also I've had a missed call and it worked but if theres 3 or more missed calls it seems to mess it up.
Mike.
