Which one do you think its better any why ?
Does 3650 support Java app ?
What is 3650 screen resolution ?
How many colors does 3650 has ?
GPRS, Bluetooth, IR ?
Thanks,
Mike
Thanks,
Mike
These links answer your questions:
3650 features: http://www.nokia.com/nokia/0,8764,2275,00.html
N-Gage features: http://www.n-gage.com/R1/en/gamedeck/gamedeck_tech_spex.html
I'd go for an n-gage, simply because its cheaper, and has better gameplaying abilities. However, it has no camera, and the 6600 can also play ngage games.
...but it looks like you're talking to a Game Boy Advance when you're on the phone with it.
IMO,it looks a lot better then a GBA,i love the design(well,not the MMC slot design) and considering the price and the features its a way better choice then the 3650.
I really get a lot of attention when talking on it,that is when my little brother allows me to use it 😃
dont go for the 3650
try the 3660
Why?The 3660 is just a 3650 with a better screen and a regular keyboard.There are much better alternatives out there.
i prefer the 3650 over the n gage, the ir port on the 3650 is much more utilitarian. PLUS!!! THE IR REMOTE IS JUST WAY TOO MUCH FUN NOT TO HAVE!!!!! it has power over every thing "ever bar tv's😊'' ne way im a geek so
peace
from chilly minnesota, usa
wes
wat i meant was dont compare 3650 to n-gage but compare 3660 to 3650
3660 is better than 3650 isnt it?
