wap-not working properly
3 replies · 1,791 views · Started 16 December 2003
I used to be with orange and wap worked fine then, but now that I've changed to virgin wap won't work, I've tried to find out in the virgin booklet but it didn't help, please help!!
You may need a sim update, if your sim is slightly old then it won't have the settings for the new sort of wap, phone up virgin custumer services and they will help you
Get back to Orange - i use Orange - they`re the best - The future`s bright, the futere is Orange 😊
For only 4$ - i get UNLIMITED WAP (gprs and dialup)..
Their base package is 4$ (the smallest from all other companies)
Orange ROCKS !!
SO GO BACK TO ORAGE 😃
Cidd
