Mobiclip Video Player
7 replies · 6,845 views · Started 17 December 2003
Impressive.
I like the landscape mode.
Here's a quick video I knocked up for it..
url removed
Download them transfer to your phone..
Best
Will
-GhostDog edit-
Will,i think that free distribution of clips in the .mo format is not alowed,you'll have to pay a fee to do that.
Thats pretty damn good quite hefty on the size though....
I do qutie a bit of Flash programming and so tried to build something for it but it didnt seem to like any of the actionscript I was using all I managed to get working was a blue screen - I think its an awesome program though just need some more support for Flash...
P
Yea hefty on size but offers loads of extras like using it to play as ringtone and also handling swf content. Dosen't say much about how it handls actionscript and whether it will interpret it if it is sent from a webpage. Other than that its cool!
Well looking in the manual it handles alot of the maths of the actionscript probably the bigger problem is the lack of abilit yto handle curves and fills and alphas
Hey Will,
How did you get the Mobiclip Codec to appear in your list of codes (not sure which editing system you are using) assuming you are using either Virtual Dub or Premiere?
Pasa
Once the mobiclip encoder was installed it appeared as a codec automatically.
In Premier / VirtualDub / Pinnacle Studio / Tmpgenc
Then create the avi then drop it on MoCoderAvi.exe to encode to .mo
Bit long winded, but once scripted it can be left running 😊
Pasa - showed it to Philip and he's getting his boys to work on a full screen landscape option for oplayer 😊 😊 😊 😊
Sorry ghostdog - did not realise I could not distribute the file 😉
Will
Thats gonna be really cool to get that. Its funny how much it helps to have that option.
I might have to re-install mobiclip as it doenst show up on mine, really weird...
P
